Mach Discussion => General Mach Discussion => Topic started by: crasher20 on July 11, 2009, 06:52:54 PM
I am currently retrofitting a large 24ft x 9ft plasma table with mach3. It is equipped with 1hp ac servos for x and y axis and a 350w servo on z axis.
I'm using the smooth stepper interface on x and y axis and that seems to be working fine.
Here is the problem. I used an Eaton plc and operator interface to run the z axis using tip voltage to controll the height. This system works great with one minor hick up. I need a antidive signal from Mach3. Is there a way to configure an extra output from Mach that energizes when the servos are decelerating to freeze the THC?
One extra note this system has a rapid rate of 1000ipm and due to the servo encoder resolution running x and y directly on the parallel port is not an option.
Have never had a plasma but I think there is a plugin for THC, have you looked at that?
