Mach Discussion => General Mach Discussion => Topic started by: John W on June 28, 2009, 08:25:20 PM
I am testing some G-code and getting the feel of MACH 3 while I wait for the rest of my electronics to show up for my "soon to be" CNC Taig mill. During this time I noticed an issue I would like some clarification on.
The "Jog Follow" button beneath the small display window has not been checked yet when I run some G-code there is a following line created as the program runs. But when I check the "Jog Follow" button the following line disappears until such time as the button is unchecked. Shouldn't it be that if I check this button, the following line is visible and if I uncheck it the following line is no longer visible.
This "following line" that depicts the tool path also does not appear at all in the display window when I am testing code in the MDI tab yet in screen shots there clearly is a line that follows the G-c ode. Have I inadvertently turned something off by accident. BTW, in all cases the DROS are changing values so there is perceived movement by Mach 3 even if there are no motors attached at the moment.
John
Jog follow active means your point of view is that of the tool. The view is rideing with the tool. Jog follow off is like a stand back view where you watch the tool moveing around the tool path.
If you want the "Tool Position" to be drawn while the machine moves you can check off "Line from Last to Current" under:
Config/Toolpath/Line From Last To Current
You can also:
-Adjust the toolpath colors (in Mach4 you can change the background with a image and few other additions :) )
-Set "Origin Sphere"
etc..
Thank you. Now I understand the use of that button. I also turned on the sphere. Is it possible to alter the size of the sphere as it is rather large but that may be relative to the size of the image.
When will Mach 4 be available?
Thanks again
John
It's going to start beta testing soon. And I think it's actually Mach3, Version 4.
