Mach Discussion => VB and the development of wizards => Topic started by: engraversoflight on June 27, 2009, 05:48:23 AM
A gentleman got me going in the right direction with the code below. Quick background: I use a couple hundred different toolpaths generated from vcarve. what i want to do is load one at g54, a different one at g55, and a different one at g56. Those positions are 0,0; 0,10; and 0,20. Then i want to hit start and walk away. This guy gave me code to run 2, but I want to run 3 at three different offsets each time i start the machine. So how can I create a button that says, "Load Multiple" then use this code? I'm not a VB programmer, but I'm trying to learn something.
Below is my code for opening then running 2 g-code files. The Run Button code will run either 2 or 1 depending on led#1110. I hope someone can find it useful.
Bill
Load Button
If GetUserLED (1110) = 1 Then
DoOEMButton (216)
While IsLoading()
Wend
cutfile = (FileName())
SetUserLabel (2,cutfile)
DoOEMButton (216)
While IsLoading()
Wend
camerafile = (FileName())
SetUserLabel (1,camerafile)
Else
DoOEMButton (216)
While IsLoading()
Wend
camerafile = "None"
End If
Run Button
If GetUserLED (1112) = 0 Then
SetUserLED (1111,1)
camerafile = GetUserLabel(1)
LoadFile (camerafile)
While IsLoading()
Wend
Sleep (1000)
DoButton (0)
While IsMoving()
Sleep (2000)
Wend
Sleep (5000)
SetUserLED (1111,0)
SetUserLED (1112,1)
Sleep (100)
End If
If GetUserLED (1112) = 1 Then
cutfile = GetUserLabel(2)
LoadFile (cutfile)
While IsLoading()
Wend
Sleep (1000)
DoButton (0)
While IsMoving()
Sleep (2000)
Wend
Sleep (5000)
SetUserLED (1112,0)
Sleep (100)
End If
Else
SetUserLED (1112,1)
Sleep (1000)
DoButton (0)
While IsMoving()
Sleep (2000)
Wend
Sleep (5000)
SetUserLED (1112,0)
End If
