Mach Discussion => General Mach Discussion => Topic started by: c+c on June 04, 2009, 02:13:53 PM
I would like to add some jogging buttons, without using the printer port.
The computer only has USB ports. So is there a simple device I can buy to which I can connect a couple of keys?
Pokeys will allow you up to 55 digital inputs or outputs.
Thanks, orderred one immediately!
You can also use a few of the I/O as analogue inputs so that you can have a feed override pot and spindle override as well :)
