Mach Discussion => General Mach Discussion => Topic started by: jdmaya on May 22, 2009, 09:02:36 AM
How can I activate a user button with an external signal.
thanks.
Set up an OEM Trigger in Ports and Pins>Inputs. The Hotkey for the screen button must match in the Screenset file and the OEM TRigger.
If its a VB button then I think you will be best to get MachMad plugin, it makes things like that easy.
