Mach Discussion => General Mach Discussion => Topic started by: celticbern on August 06, 2006, 12:30:02 PM
Hello All..
For some reason I screwed up my computer to control box.....The Mach 2 screen shows the x,y,z moving when I press the HOTKEYS but it will not move the CNC motors....I must have locked out something or pressed the wrong key.
I double checked all cables etc and still nothing.
I have been using Mach 2 for a long time for my Irish and Celtic Wood Carving Rough Outs and it is wonderful.
I cannot figure out what I locked out but any input will be greatly appreciated.
Kindest Regards,
Bernie Fay
Http://www.carvingceltic.com
Sounds like your port or pins have been screwed up, check that all the pins are configured correctly and that they are all enabled and assigned to a port. Also make sure the port address in Mach is the same as it is in device manager.
