Mach Discussion => General Mach Discussion => Topic started by: osman100 on April 13, 2009, 09:57:02 AM
in mach 3 how can i change between mm and inches
G20 is inch G21 metric. If you mean to have the machine set up as default in one or the other then you can set that from Config menu then Units. You will then need to retune motors if you change it, best a=lso to restart Mach after the changes.
ok thanks
