Mach Discussion => General Mach Discussion => Topic started by: stitchlips on July 31, 2006, 09:31:45 PM
I am very new to this. I was given a used sherline machine with a camtronics controller. I have managed to get the machine to run. I am now just messing around with cuts and my o's have an odd shape. What am I doing wrong?
In this picture the o is about an inch tall. I made this with the text wizard in mach 3.
I am using a .5 inch v bit. It was all I had laying around at the time.
(http://www.siliconesoapmolds.com/images/o.jpg)
Do you have the correct steps/unit set in the motor tuning? Have you tried the circle wizard to see if that makes a round circle?
I am not sure if I do or not. How do you know if they are correct?
Best way to do it is go to settings page and click on the "Set Steps per Unit" button and follow the directions for each axis. You will need some form of measuring device to read the actual distance travelled, a dial gauge could be used. Once you have each axis done you can try the text again and see if its right, also try the circle wizard to see if it does a proper circle.
Grab the mill table while it's powered down and see if you can move it any noticable amount, checking for large backlash problems.
I have been reading on backlash and I think that is my problem. Both the hand wheels on thex and y axis turn quite a bit before moving the table.
