Mach Discussion => General Mach Discussion => Topic started by: Toc Brian on March 28, 2009, 08:25:44 AM
I have the touch probe setup on my machine and sometimes it feeds down touches and comes up .300 and stops as it should
But sometimes it goes up 2 inches dwells and goes up again.....Why is it doing this...?
Hi Brian,
I gave you a possible fix over on the TOC, let us know if it helps, ok?
Thanks- 8)
Thanks Dave....I looked all over there but all I could find from gary was he downloaded the screen and code seperate.....where is the code?
I believe the latest version is here in post 257 from Greg.
http://www.cnczone.com/forums/showthread.php?p=578105#post578105
He may even pop in on this thread to chime in as well-
Possibly because you are starting the script when in a G91 condition.
If you are using a Z zero routine (not clear if that is what you are asking about) then the post Budman pointed to shows a script which covers for that situation.
A lot of the script examples that are around, don't.
Greg
Great....Thanks Guys...Will give it a Shot
