Mach Discussion => General Mach Discussion => Topic started by: ahmedrehan on March 22, 2009, 01:41:28 PM
Following are the problem i am facing with mach3 turn i am using uhu drive.
1. As the tool changer work it changes program coordinates randomly but machine coordinates remains 0,0
2. when any limit switch is hit it changes the hotkey direction with the same hot key the machines move in opposite direction
3. It dose not remember the parameter instead of i save the setting
4. in general configuration should i select absolute or increment?
5. can i have screen shot for general config for lathe.
Ahmed
Please attach your xml and any macros you are using.
ok will do that but one thing i want to ask that my lathe has turret which is homing in X+ direction and all move is in -ve direction for x is it ok?
X0 should be when the X axis is on the lathes centre line, all moves should be in a positive direction. If your X axis homes to the positive then you want to set up a Home Off Distance so that when homed the machine coords DRO for the X reads the amount it will take to move the tool to X0.
Hood,
Attach please find the photo of turret and chuck . Please let me know which side x should home towards the door of machine or the orther side?
Regards
Ahmed
Ahmed
It doesnt really matter which way you have it homing, however the normal direction would be away from the door. What is important is X0 should be when your tool is at the exact centre line of chuck. All moves towards the back should be positive.
