Mach Discussion => General Mach Discussion => Topic started by: jguillen on February 21, 2009, 01:56:12 AM
Hello All,
I would like to know if it is possible to set up my diy MPG so that I can change the counts/unit value via a switch. Currently all I have hooked up is the encoder and one switch, which toggles between the different axis. I am hoping to add a knob w/ 3 positions which select 3 different counts/unit of movement. If any one has any experience with this please share with me your thoughts.
Thank you in advance,
Jose.
I have three switches on my lathe panel, one switches full jog mode another multi step mode and the third will toggle the units for the multistep.
