Mach Discussion => General Mach Discussion => Topic started by: ErnieD on February 17, 2009, 11:55:39 PM
I recently had to up grade to a new computer and the computer people transferred all of my files from the old computer to the new one. Now when I try to run Mach3, not at the machine but on the house computer, I cannot get any code to run. The reset button is red and the scrolling message reads " emergency mode active press reset". Nothing happens when the reset is pressed. Anyone know what is wrong?
ErnieD
Did you transfer the Mach3 XML file containing all your configuration settings from the old Mach3 directory to the new one?
Change the active state of the E-Stop Input in Ports and Pins.
Hood,
Where do I find ports and pins?
Ernie
Config menu, ports an pins then inputs, scroll down to EStop. Possibly the Tormach version being an OEM may not let you in there :(
My apologies to everyone; old timers disease must be setting in. I forgot to set up for running offline.
Thanks to all who replied,
ErnieD
aint that just because he is not offline
