Mach Discussion => General Mach Discussion => Topic started by: johnnydoughey on January 19, 2009, 05:47:25 PM
I've cut my 1st piece after being certain everything would be perfect...
I now have a perfect mirror image of my name engraved in MDF. :)
The mirror image is from the Y axis. Rather than changing my Y motor leads, I was wondering if there was a Mach3 setting which would solve this problem?
Also, when I jog using the keyboard, I would like to have it jog slower than it does so I can get closer to the my starting point for my gcodes. Any suggestions?
Thanks much...
Config > Homing Limits, check "Reverse".
Hit the tab key and set the slow jog %
