Mach Discussion => General Mach Discussion => Topic started by: tubular2000 on January 19, 2009, 01:56:53 PM
hi all
i recently ran into a thread problem and finaly have it runnign. this issue had me wondering if there is any reason to use g76 over g32 beside the fact that the code is shorter. if it is generated by a whizzard or a cam software the lenght of the code doesn't really matter?
No reason I can see, a lot of people use G32, just if you are hand coding its much easier with G76 I think.
One thing you may have to watch however is if you run any code with a G76 in it and you have the macro in test mode then you may get problems.
