Mach Discussion => General Mach Discussion => Topic started by: tweeter on December 18, 2008, 11:31:58 AM
Title: Question about db25 hookup
Post by: tweeter on December 18, 2008, 11:31:58 AM
Hello my question is should I hook up my StepGenie IC diy board to my pc, because I am reading 5v coming out of the step input and dir input. I hate to sound so noobish but we all have to start somewhere. I did ground the inputs to see what will happen and I got motion from the stepper. But before I go ahead and break my pc I wanted to check here.
Title: Re: Question about db25 hookup
Post by: Hood on December 18, 2008, 03:56:07 PM
Not sure what you are meaning, the Step and Dir are OutPuts.
Post by: Chip on December 18, 2008, 04:38:56 PM
Hi, Tweeter
Your printer port uses 5 volts & 0 volts to send or receive data, If your board inputs are floating at 5 volts, Then by grounding/pulsing them you'll get movement.
That's why Mach3 has Step/Direction  "Low Active" settings in Config, Ports & Pins, Motor Outputs, You can select.
The only precaution is that your Printer port should have No More than 5 volts applied to it, Grounding or 5 volts applied to it is Normal.
Hope this Helps, Chip
Post by: tweeter on December 18, 2008, 05:09:55 PM
Thanks for the help guys. I never hooked anything on a printer port I was thinking better to sound stupid than kill a 1000.00 dollar pc. Thanks again
