Mach Discussion => General Mach Discussion => Topic started by: ronald4418 on November 25, 2008, 12:20:38 PM
Is there a problem with the servers? Everytime I try to upgrade to the newest locked down version. The download speed is awful. You'd think I was trying to download with a 14400 modem instead of a highspeed dsl modem.
Hi Ronald, I just tried it for you and it seems to be working ok for me.
I just tried it again and it gets to 1% and hangs there. It say's the download speed is 323kb's. per second and should take 1.5 minutes. After 10 minutes it's still at 1%. I checked and cleaned out my registry to now avail.
Very weird as I just checked again and I get the complete 25.8 meg download in around 4-5 minutes and I have slow DSL.
Try it here:
http://www.machsupport.com/downloads/Mach3Version3.042.020.exe
Seems that if you click run it will hang, but if you click save it takes around 30 seconds with a high speed dsl modem.
Very odd, but you have it downloaded now?
Yes, thank you.
You might wanna check for some spyware that is working in the background using your system for some evil purpose ! I have had it happen a couple times and it be a definate problem
