Mach Discussion => General Mach Discussion => Topic started by: DennisCNC on November 21, 2008, 11:52:50 PM
Title: Jogging with keyboard and MPG?
Post by: DennisCNC on November 21, 2008, 11:52:50 PM
Can I make Mach3 3.042 jog with the keyboard and MPG together? If yes how?  When I select MPG on the (TAB MPG screen) the keyboard doesn't jog.
I wanted to have the keyboard jog at full speed and the MPG slow to get the machine to spot I need,  the X axis is long so when by the keyboard I would jog it to the approx position and then walk over to the moving head that has the MPG on it and get it to the spot I need.
Dennis
Title: Re: Jogging with keyboard and MPG?
Post by: Hood on November 22, 2008, 04:15:51 AM
You can only use one or the other as far as I know. What you could do is have a physical button set up on your pendant to change between Jog and Keyboard, that would allow you to change back and forth easily.
Post by: DennisCNC on November 27, 2008, 02:14:37 PM
The button is what I will do.
Thank you Hood!
