Third party software and hardware support forums. => SmoothStepper USB => Topic started by: Anton on November 20, 2008, 03:33:06 PM
Just discovered that manual "Override limits" does not work. Red led flashes, I push a Reset button, but I can't jog out of the switch. The same time AutoOverride Limits works well, homing works well, limit switches themselves works well. Everything, concerning a limit switches, works well, except of a manual Override limits. Does it relates somewhere to SS?
Not sure, I always have Auto enabled. If no one else comes back with an answer I will try and remember to test tomorrow if I get back to the workshop in time, if not it will be Saturday.
It works but it's funky. You have tho click the reset button 2 times. Then it should allow you to move off your limit switch.
HTH,
Sid
Today I have tried this with PP version and manual limits override works well.
Thanks, I'l bear it in mind.
