Mach Discussion => General Mach Discussion => Topic started by: dfurlano on November 12, 2008, 06:52:13 PM
I found them in the user manual but I cannot find a reference to Call SetVar(1000,*********) I am assuming this is the tool offset parameter. Can someone point to where these values are listed in the Wiki or manual?
the original Mach3 mill give a listing of Parameters........
BUT, the Tool Offset Parameter parameter is a DRO, look at the Wiki Docs under VB DROS.
scott
Thanks for the info Scott.
I searched the Wiki and looked at every reference for DROs, downloaded the excel spreadsheet with the values printed, and looked through Art's files on the Yahoo boards but I have not found any reference to the VB DRO 1000. I really just wanted to know if there are other DROs like 1000 that I should know about.
DROs above 1000 are used by wizards so can vary depending on what screen set you have loaded.
Ron,
That was the information I needed. I never thought to look on the Offset page and see what variables were used. I am using the default screen set and now I can see that 1000 is the "edge finder diameter" which is what I do not want!
Thanks for helping.
Perhaps I am misunderstanding but, your original post said your looking for the Tool offset dro? I am assuming ht.?
From the Wiki under DROs:
Tool Length Offset DRO(32)
Machine Z coord - Z Work Offset - Tool length DRO(180)
Scott
No my question was that I wanted to know what SetVar(1000) was doing. I could not find a reference to it and I was assuming it was some type of tool offset. Come to find out it is an offset but used in X-Y probing as a diameter offset used on the "OFFSETS" page of the standard screen sets.
But more important is the knowledge that variables above 1000 are used in wizards. Although I am still wondering why 2000, 2001, and 2002 are used to retrieve x,y, and z probing positions. Is it just arbitrary?
Anyhow, just tying to learn.
Thanks for the help I know it can be frustrating answering these basic questions.
Much appreciated.
Dan,
Not a problem, we all started where you are.......
UserDRO's and UserLED's range from 1000-2255
who ever made the screen your looking at, just choose those numbers arbitrarily.
scott
