Mach Discussion => General Mach Discussion => Topic started by: rodneya on July 06, 2006, 01:01:10 PM
Title: No movement
Post by: rodneya on July 06, 2006, 01:01:10 PM
I just download the demo of Mach 2 for my maxnc 10 ol got all the driver (from the forums ) the motor sound as if they are trying to step but there is no movement i am at a lost i want to be able to manual step the machine before i buy the software.
Rodney
Title: Re: No movement
Post by: Brian Barker on July 06, 2006, 01:33:08 PM
Did you check Max NC mode under the ports and pins?
Post by: rodneya on July 06, 2006, 04:39:43 PM
yes the maxnc mode is check
Post by: Brian Barker on July 07, 2006, 07:46:05 AM
Do you have any info on the pinout of your drives? I am thinking that you are not running the wave drives.... I am sorry I have never seen the MaxNC drives or worked with them... But I will do my best!
Post by: rodneya on July 07, 2006, 10:18:44 AM
no i do not have the pinout of the drives i will call maxnc today and try and get the pin outs from them
Post by: samtc on September 10, 2006, 11:05:57 PM
Hi, rodney
I am new to the forum and I have Maxnc 15 CL that I try to get going with mach but I had the same problem as you.
did you get your machine to work?
if so can you shared the some information.
Post by: Brian Barker on September 12, 2006, 10:21:22 AM
There are docs for the pinout on the FTP server :) I will see if I can get an XML from a guy that I helpped out that other day and post it on the FTP server
