Mach Discussion => General Mach Discussion => Topic started by: Murray6301 on November 06, 2008, 08:47:45 AM
I'm new with a Taig CNC, Mach 3 and BobCadCm to learn. I notice that the last line of any code does not show in the Mach 3 Program Run window. In fact, when I write a subroutine starting with M98 and ending with M99, the subroutine runs, but the program stops at the last line in the subroutine - and doesn't return to the program. I found that if I added another M99 (one after the other), the code now shows in the window and the program runs correctly. Any help would be appreciated.
Add some whitespace to the end of your code.
Get into the habit of making the last line of your code a % doing that lets you know you have ended the previous line by moving on to the next. You can also do a swarfboy has said but looking at the code in notepad etc doesnt let you see you have remebered to press return after the last line where if the % is there you can see instantly.
Thanks for your help. Now I have another problem. A white window appeared below the Mach 3 screen and had an option to "Simply window" and I clicked on it. Now I have a gray screen with only the FIle, Config, Function Cfg's, etc. across the top. I've lost all the DRO's and other window info. Any suggestions?
Been a long time since I have done that, try going to view menu then load screens then choosing the 1024.set If that doesnt work then I will try and remember what you need to do.
Thanks again. That was the solution. I'm new, but I already can tell you that I really appreciate the help you guys give. Hope someday I'll be smart enought to help others.
