Mach Discussion => General Mach Discussion => Topic started by: softselect on November 01, 2008, 03:17:07 PM
Hi Everyone,
I am trying to write a macro that will move to a home or tool change position for milling
it looks like this
Feed=GetDRO(18)
ofset=GetDRO(0) - This must read which coordinate is active G54, g55, g56 etc.
code "g54" - This must set G54 (Machine coordinates
Code "g00 Z0" - This must move Z home (or tool change position)
code "g00 x0 y0" - This must home X and Y
SetDRO(18,Feed) - this must restore feedrate
setDRO(0,ofset) - This must restore coordinate that was used before homing (this line seems to be the problem)
sadly this macro doesn't work
can anyone please help
There are a lot better at VB and G Code than me but give this a go and see if it does what you want. I am not sure if you actually need to set your feedrate DRO as you have because they shouldnt really change anyway.
Feed=GetDRO(18)
ofset=GetDRO(0) 'This must Read which coordinate is active G54, g55, g56 etc.
Code ("G53 G0 Z0") 'This must move Z home (Or tool change position)
While IsMoving
Sleep (10)
Wend
code ("g53 G0 x0 y0") ' This must home X And Y
While IsMoving
Sleep (10)
Wend
Call SetDRO(18,Feed) 'this must restore feedrate
Call setDRO(0,ofset) 'This must restore coordinate that was used before homing (this Line seems To be the problem)
Just been messing with it, maybe this would be better but again I dont really know what I am doing so test with caution.
Feed=GetDRO(18)
ofset=GetDRO(46) 'This must Read which coordinate is active G54, g55, g56 etc.
Code ("G53 G0 Z0") 'Moves Z to Machine CoOrds Zero
While IsMoving
Sleep (10)
Wend
code ("g53 G0 x0 y0") ' Moves X and Y to Machine CoOrds Zero
While IsMoving
sleep (10)
Wend
Call SetDRO(18,Feed) 'Sets feedrate DRO (Not sure this is really needed)
Code ("ofset") 'Sets back to previous offset
End
Welcome to my world - :D
Thanks Hood, thats done the trick ;D
