G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Dave houghton on October 18, 2008, 05:51:16 PM
Hello to all
I live in South Africa just outside JHB.
Very new to Mach3 and cnc, OK with manual milling and turning. I have a cnc Sherline mill so I'm hoping to learn as I go along. It will mainly be used as a hobby - making small models.
It's seems I'm already stuck! The Write Wizard produces the I J (offsets) in "absolute" mode I would like them to be in "Incremental" mode, is there any way to do this.
:) Dave
Hi Dave,
I do not think this is possible in write.
Why do you need incremental I&J?
Graham
Hello Graham
The Sherline CBC mill came with ENC (Linux) and that uses incremental I&J. It might be possible to change ENC to absolute. I'm still very new at this so stumbling in the dark a bit.
Thank you for your reply, at least I know it's not ME!
Best regards from South Africa
Hi Graham
Sorry CBC should be CNC and
ENC should be EMC
I didn't use the spell check correctly.
regards
