Mach Discussion => Mach Screens => Flash Screens => Topic started by: azambuja on October 15, 2008, 10:06:08 AM
Title: Function to get a number from a string!?
Post by: azambuja on October 15, 2008, 10:06:08 AM
Hello friends!!!
I need to count the numbers of letters of a _root.something (exemple: String="something" to get Number=9, or something like that) and with this number I can use it in a If condition.
Thanks for your supply.
Azambuja
Title: Re: Function to get a number from a string!?
Post by: ger21 on October 15, 2008, 10:31:29 AM
Try:
mystring = "something"
X = LEN(mystring)
X should be 9.
You might be able to just do:
X = LEN("something")
Post by: azambuja on October 15, 2008, 10:58:26 AM
Hey man!!
Thanks but it does not work. Maybe I am not using it in the right way.
Azambuja
Post by: ger21 on October 15, 2008, 12:43:08 PM
Is it case sensitive? Try Len and not LEN? That's the VBA function. Maybe the script function is different. I'll have to check the docs.
Post by: zealous on October 16, 2008, 02:29:39 AM
I think he meant in Flash and not VB
This will return the number of your strings length:
Code: [Select]
MyString.length
this will check to see if the digits are 9:
Code: [Select]
if (MyString.length == 9) {
trace("Is 9");
} else {
trace("Is not 9 it is:"+ MyString.length);
.....but you can take the code they gave for VB  and run it in flash but you have to do it like this and I dont belive you can split and join in Mach's VB
fscommand("VBMacro" "some VB here")
Post by: ger21 on October 16, 2008, 08:09:10 AM
Oops, didn't see that it was in the Flash section. :)
Thanks Jason
Post by: zealous on October 17, 2008, 03:27:02 AM
NP  :)
Post by: azambuja on October 17, 2008, 06:43:37 AM
Thanks Zealous!!
That worked. Now I can continue to work.
Azambuja
