Mach Discussion => Mach Screens => Topic started by: rrgnome on June 24, 2006, 04:05:39 AM
Title: Why are my custom screens all messed up ?
Post by: rrgnome on June 24, 2006, 04:05:39 AM
Any ideas why every time I try a custom screen it does not display properly ?
Here is what Hood's touch screen looks like...all the buttons are missing, and there
seems to be a problem with window refresh (white parts only dissapear after moving the window off
screen and back). The *.set file is in root of Mach3 directory, the Hoodbuttons directory is in Mach3/Bitmaps.
Have tried putting it in Mach3/Bitmaps/MillBitmaps, even tried dumping the png files into ../MillBitmaps.
but nothing helps. Whats wrong ?
E.K
Title: Re: Why are my custom screens all messed up ?
Post by: Hood on June 24, 2006, 12:25:48 PM
You need to use a later version of Mach 3, I use version 1.9.037.
Post by: zealous on June 26, 2006, 07:18:17 AM
or under:
Config./State/Auto resize screen
Make sure the box is check to auto resize, by default it's turned off.
I also like to have the high resolution check as well for better appearance.
