Mach Discussion => General Mach Discussion => Topic started by: Peter Zicha on June 05, 2004, 08:16:17 AM
Is it just my imagination or does a desktop system just work better , everything went great upgrading from my laptop to desktop including importing all the settings but when I try to access the pins settings In the config menu I get this warning..... ???
Hi Peter
I have just been through a similar experience, problem with my PC, had to build another, transfer went perfectly, and i did it as follows.
Copied the old Mach3 directory over to the new PC
On the new PC i installed Mach3 as per normal
HTH
Phil_H
Never saw that one. Make sure you you reboot per installation instructions. The latest test veresions automaticaly
do a reboot. May want to try downloading and reloading again. Post the version you are installing.
Peter, that looks like a flash screen, possibly it might have to do with that?
Possibly try a standard screen and see if you still have that issue?
The only time that will come up is if I go into the config editor and try to access port and pins everything else is accessable - other than that since I over wrote the new install with the mach3 system from the laptop everything is as it was on the laptop , works beautifully and much smoother , and I did the reboot . Its no big deal since everything still functions at 100% but was curious if Art can shed some light on this one
