Mach Discussion => General Mach Discussion => Topic started by: ketil1 on June 22, 2006, 11:04:50 AM
Title: motor direction
Post by: ketil1 on June 22, 2006, 11:04:50 AM
my x axis is moving in the wrong direction.
The controller must be wired wrong.
Using mach3
any advise or info on how to fix myself.
thanks
Title: Re: motor direction
Post by: ketil1 on June 22, 2006, 11:30:32 AM
Config/Homing & Limits/ REV column. Check or uncheck the box
Post by: method13 on June 22, 2006, 11:37:08 AM
Using Mach2....
You can reverse the motors under Config. then Motor reversals switch the one you need. Also under config. you can go to homing and switch the direction that you home the machine in if you need to.
Greg
