Mach Discussion => General Mach Discussion => Topic started by: bfairey on October 07, 2008, 12:16:58 AM
Title: AH-HA into Mach 3
Post by: bfairey on October 07, 2008, 12:16:58 AM
I am on the verge of firing up a MACH3 into a AH-HA box via a SmoothStepper.
The main problem is making the cable from the SS 20p connector to the AH-HA
DB36 pin connector.
Will keep you informed.
Brian.
Title: Re: AH-HA into Mach 3
Post by: bowber on October 07, 2008, 04:16:33 AM
Hi
I just removed all the AH-HA stuff and used a newer computer with Mach 3.
Are you reusing the AH-HA interface card?
Steve
Post by: bfairey on October 07, 2008, 07:15:56 AM
No I dont think the interface card will work with MACH3
I also brought a new(er) computer so decided to use the USB port
thats why I am using the SmootheStepper board as it will take the USB
connection.
Brian.
