Third party software and hardware support forums. => PoKeys => Topic started by: kencor1 on October 06, 2008, 09:06:58 AM
I have my pokeys board setup and configured for an input on pin 1 and I have a switch wired to it. My question is how do I program Mach to read the input for the button to reset mach ( for example). If someone could give me a demo Brain or tell me what I need to do to get this to work I should be able to figure out the rest.
Tom
UsePoKeys software to configure pins for input or output
Set Mach3 to Port 10 pins 1 - 55
Each input can also be used as a keystroke emulator for Mach3 or any other application.
regards
Boris
Thanks for the response but I am not sure of exactly what I am doing. I have configured the pokeys device for input on pin 1, sent to the device. Then I bring the pokeys device to my Mach computer and plug it in to the USB. In ports and pins in mach I set OEM trigger1 on inputs to port 10, pin 1. I then configure the system hotkey for oem trigger 1 to Oem#1021(Reset). I wired a button to pin 1 on the pokeys board and the ground end of the switch to the GND on the pokeys board. When I press the button nothing happens. I pull up the pokeys menu in mach and it shows nothing. I have the pokeys devive enabled in the plugin. I must be doing something wrong but I have no idea what. Please Help.
Tom
Tom!
You are doing all right.
We slightly changed comunication protocol for PoKeys55 in latest software version because of more performance under Mach. New protocol is not supported in Mach plugin yet.
Just talked with our developer. New software update with improvements asked by Art will be ready in a week. (more Mach functionality)
After that Art promised that he will update Mach plugin.
regards
Boris
