Mach Discussion => General Mach Discussion => Topic started by: simolke on June 18, 2006, 02:13:20 PM
I have a tag mill it workers fine with Mach 2 the motors wont work with Mach 3/4 an I bought license . I received secend copy of license an will still not work . Wizard said unlicensed file. can some one help :'(
Look in mach3 Directory, is there a Mach1Lic.dat file? If there is not copy it from the Mach2 directory and place a copy of it in the Mach3 directory.
There a Machlic in the file I have rerun file several times
under help / about do you see your name?
Also you should be able to move your motors is you don't have a licanse... Could you please post your Mach2 and Mach3 XML files? I would like to check them to see if you have a bad setting.
Brian
how do i post the file to you
how do i post the files to you so you can inspect to see if it's corrupted
Try this
hear is Mach2
The Mach2 one is an XML not a sys file :) i think you got the wrong one..
Is whathyou want
You need to set up your ports and pins :( If you look you have all the Step and Direction pins set to 2 & 3... once you set them to what you have in Mach2 you should be up and running :)
will this fix the wizard problem to . wizard said that I was unlicensed .
Motors running now . Last time I rubout Mach3 must have loss setup . Only problem now is Wizard stated unlicensed .
Hi:
Thats because the Conversational Wizardsa are a separate license available only from www.newfangledsolutions.com
Art
I wouldlike to thank youfor helping me through my problems an I will be gitting the wizard but don't like using paypal . Is there a nother way. ;D
If you would like I can send you my address off line and you could send a check..
Hope that works for you
Brian
