Mach Discussion => General Mach Discussion => Topic started by: Vmax on December 14, 2005, 08:42:58 AM
When I bring in a DXF 2d drawing how is the best way to control the Z axis. Do I just manually change the code for the different heights or can I set up the drawing and put the different height sections on separate layers before I import it????? Thanks Terry Parker
The best way is to use the layers for the depth's
Hope that helps
Brian
