Mach Discussion => General Mach Discussion => Topic started by: Flash Gordon on September 24, 2008, 08:38:56 AM
Title: Heat Sink for Gecko 340 Drives
Post by: Flash Gordon on September 24, 2008, 08:38:56 AM
Hi all
I am building a panel for a digitizer conversion
Do I have to place the drives on a heat sink or can I just bolt them to the chassis plate of the panel and then have a fan blowing cool air over them ?
Flash Gordon
Title: Re: Heat Sink for Gecko 340 Drives
Post by: HimyKabibble on September 24, 2008, 09:15:22 AM
Flash,
     I looked on E-Bay, and found inexpensive ($10 each) Pentium/AMD CPU heat sink/fan assemblies.  They keep the Geckos nice and cool, and take up very little space.
Post by: Flash Gordon on September 24, 2008, 10:36:49 AM
Hi Ray
Thanks for the reply. E-bay is out for me as I live in South Africa and as far as I know Paypal does not accept our credit cards something to do with fraud.
I already have a 220v electrical cabinet fan. Would this be enough to keep the drives cool.
Regards
Scott
Post by: Hood on September 24, 2008, 04:03:11 PM
Should be fine bolted to the chasis.  The G202 that I have on my mill just fix to a plate on the side of my computer, no fans but then again Scotland is not exactly known for its heatwaves ;D
Post by: RICH on September 24, 2008, 06:42:05 PM
FLASH GORDON,
Adding some heat transfer material before you mount the drives to a plate will help take away heat. Can buy from any electronics source or even a small tube from Radio shack will do if there is one around you neck of the woods.
Post by: HimyKabibble on September 24, 2008, 07:42:28 PM
Hi Ray
Regards
Scott
I ran mine for several weeks with the Geckos bolted to a 3/8" thick aluminum plate.  No forced airflow at all.  They were quite happy like that.  So, bolted to your case, with some airflow, I suspect you'll be just fine.  Get some silicone heat-sink grease, and coat the bottom of the Gecko, so it has good heat transfer to the case.
Post by: Overloaded on September 25, 2008, 06:24:21 AM
Hey HOOD,
Just curious....what is this board ?
RC
Post by: Hood on September 25, 2008, 06:35:04 AM
I-Pac keyboard emulator.
Post by: Overloaded on September 25, 2008, 06:49:39 AM
Thanks Hood,
RC
