Mach Discussion => General Mach Discussion => Topic started by: bsouthnow on June 13, 2006, 07:25:39 PM
Hey Guys and Gals!
I'm almost there with the lathemaster milling machine conversion, but I need help again. When I tell my milling machine to reference home all, my z axis rides to the top of the tower, trips the switch and reverses as it is suppose to. Before the home command satisfies itself and proceeds to the next axis, I get a limit switch active for the z and the program disarms the system. I have the soft limits set at 0 and -7 for now and have the soft limits button not active. I've set the home/limit ref value to .1 and -.1 but nothing works. It seems to work sometimes and not on most others. I hope I have described this so someone can understand and help! Wonderful site for us beginners.
billyjack
;D
Try setting the debounce to about 1500 under the Logic settings :)
Thanks Brian;
I did that very thing yesterday and cleared up my problem. Guess I should have read more before I posted.
Thanks again!!!
billyjack
