Mach Discussion => General Mach Discussion => Topic started by: RICH on September 19, 2008, 04:10:21 PM
Title: MACH DEVELOPMENT VERSIONS
Post by: RICH on September 19, 2008, 04:10:21 PM
Just wondering which one to use. ???
Started with 3.041( threading didn't work otherwise seemed solid for my use)
                  *(but have a version in which threading works that satisfies my needs but still lists as 3.041)
                  3.042.003 ( have display problems / won't zoom in enough to see the cutting )
                  3.042.007 currently listed
                  3.042.008 was listed but removed ( downloaded it but never installed it )
Hm....... going  back to *3.041 unless 3.042.007 has some advantage.
What's the better of them all?
Title: Re: MACH DEVELOPMENT VERSIONS
Post by: Hood on September 19, 2008, 04:16:08 PM
I am using 009 now but have been using 008 for a while and it seems stable. 008 was superceded by 009 on the downloads page but a problem with the instaler and Vista was found so it was removed, should be back up again soon with the Vista fix.
 008 is probably the best of the latest development ones to use then when 009 comes out again it should be the best :) But remember there have been BIG changes in the 00* versions and although most issues seem to be fixed there may well still be some.
Post by: RICH on September 19, 2008, 04:22:42 PM
Thanks Hood,
Gees, that was quick. Can you see as I type. If that's the case I won't type bad stuff anymore about you anymore. ;D
Post by: Hood on September 19, 2008, 04:25:25 PM
I actually start typing before you ask the question, just I am a slower typer than you ;D
Oh and dont worry about typing bad things about me, I am old enough and ugly enough to take it ;)
Post by: Overloaded on September 19, 2008, 04:35:27 PM
....and getting pretty used to it. ::) :D ;D
Post by: Hood on September 19, 2008, 04:44:39 PM
(http://forums.pcper.com/images/smilies/extras/rofl.gif)
Post by: edvaness on September 19, 2008, 07:30:58 PM
AND- The Hoods always right.   ;D
Ed
