Mach Discussion => Mach Screens => Flash Screens => Topic started by: azambuja on September 10, 2008, 07:01:04 AM
Title: right click in mach screen
Post by: azambuja on September 10, 2008, 07:01:04 AM
Another question, can I disable the mouse right click when running a flash screen in mach3.
Because this can interfere the user.
thanks
Title: Re: right click in mach screen
Post by: zealous on September 10, 2008, 05:52:35 PM
Hey,
To remove Content:
Code: [Select]
var rootMenu = new ContextMenu();
rootMenu.hideBuiltInItems();
_root.menu = rootMenu;
Another way to  Remove content:
Code: [Select]
Stage.showMenu = false;
Right click detect:
Code: [Select]
onEnterFrame = function () {
if (Key.isDown(2)) {
trace("Your right clicking")
To add to the "Right Click" menu system(also including functions):
Code: [Select]
Right Click Menu
var myMenu:ContextMenu = new ContextMenu();
myMenu.hideBuiltInItems();
var Load_menu:ContextMenuItem = new ContextMenuItem("LOAD GCODE", load_fun, true, true, true);
var edit_menu:ContextMenuItem = new ContextMenuItem("Edit GCODE", edit_fun, false, true, true);
myMenu.customItems.push(Load_menu,edit_menu);
_root.menu = myMenu;
function load_fun() {
fscommand("Button", "216");
function edit_fun() {
fscommand("Button", "115");
Jason Blake
