Mach Discussion => General Mach Discussion => Topic started by: jeffmorris on September 03, 2008, 02:34:59 PM
I need help in setting up SmoothStepper and Mach3 software. I installed the SmoothStepper driver and Mach3 plugin but I may have made mistakes while setting up SmoothStepper and Mach3 software. Under the "Plugin Control" menu, there should be two menu items related to SmoothStepper but I'm missing those menu items.
How did you install the plug-in? You should have placed it in your Mach 3 folder and then double clicked it. That would have placed a smooth stepper .dll file in your plug-ins folder. Check to see if you have the plug-in for the ss in your plug-ins folder.
Have you enabled the plugin from the Config menu then Config Plugins?
You may need to restart after you do that.
