Mach Discussion => General Mach Discussion => Topic started by: Edison on August 18, 2008, 09:53:49 AM
Title: How to use the VB script instead of the Cycle start button??
Post by: Edison on August 18, 2008, 09:53:49 AM
Thanks!
Edison
Title: Re: How to use the VB script instead of the Cycle start button??
Post by: ger21 on August 18, 2008, 10:02:42 AM
Can you explain what you want to do a little better? I don't quite understand what you want to do.
Post by: Edison on August 19, 2008, 08:57:17 AM
Hi, Gerry:
   I want to used the vb script code to instead the "run" function¡£
Edison
Post by: Hood on August 19, 2008, 09:43:24 AM
DoOEMButton(1000)
