Mach Discussion => General Mach Discussion => Topic started by: josh on August 16, 2008, 02:40:32 AM
Title: where can I find the quick keys for a pendant
Post by: josh on August 16, 2008, 02:40:32 AM
hello
I am trying to see where I can find all the codes or short cuts for all the keys on my DRO
I am trying to set my pendant where I only pust a button and it will do as what
I tell it to do. but I dont know what to input on the keygraber box.
i know alt-s is for cycle stop
          alt-r is for cycle start
   spacebar is for feedhold
   and ect.........
i hope this made some kind of sence i really dont know how to explain it.
Title: Re: where can I find the quick keys for a pendant
Post by: Hood on August 16, 2008, 04:44:46 AM
Have a look in the Customising Mach2 manual, it gives you the info if I remember correctly.
Post by: josh on August 16, 2008, 09:34:40 AM
iam knew to mach and I have only been using mach3
where would I find mach2 customising manual
Post by: Hood on August 16, 2008, 09:39:21 AM
Support tab at the top then documentation then down to Mach2 and you should see the Mach2 customisation manual.
Post by: josh on August 16, 2008, 01:03:39 PM
thanks finally found it.
Post by: Hood on August 16, 2008, 01:52:22 PM
