Mach Discussion => General Mach Discussion => Topic started by: CJEls on August 10, 2008, 03:47:56 AM
Hi all
I installed mach on a new hard drive after my origanal drive failed but now I can not get the turret going.I did copy the XLM file to give me the same setup and i did check that all the settings were correct. I use the same Xp software as before. It seems thet it is not reading the M6 macro. If you call for atool change the dro does change but the turret is not moving.Any suggestions
CJ
Did you remember to copy over the M6Start.m1s into the correct profile macro folder?
Hallo Hood
Yes I did.
Cj
Well if its definitely in the correct profile in the macro folder then it should work. Any more info about the toolchanger? How does it connect ie is it Modbus and PLC or just I/O from the PP or Modbus through ModIO or Arturos stuff?
Is this a mill or lathe?
In General config, top left, what do you have set as tool change option?
Hallo Hood
It is a lathe.I do not know if XP service pack 3 has a problem with the set up. I am re formating the drive and will only load Xp with service pack 2,this is how the previose drive were set up.I hope this will help.
Its just SP2 I use but never heard anyone saying SP3 didnt work but heres hoping it cures your probs.
