Mach Discussion => General Mach Discussion => Topic started by: josh on August 08, 2008, 10:05:46 PM
Title: how to fully fit mach 3 into a 17inch monitor
Post by: josh on August 08, 2008, 10:05:46 PM
I just got my new monitor 17 inch
I downloaded mach 3 into my new pc but I am trying to see how I can fit the mach3 screen so it can fully cover the hole screen on my monitor is there some kind of way I can do that I am not to good with computers . if someone knows how can you tell me the process
thanks.
Title: Re: how to fully fit mach 3 into a 17inch monitor
Post by: ostie01 on August 08, 2008, 11:07:31 PM
Try - Config
     - General Config
     - Auto screen enlarge   (check box)
Post by: edvaness on August 08, 2008, 11:09:11 PM
Josh,
I had the same problem on 1 pc. Open mach 3/config/general config. lower center is screen control. check boxs, close and restart mach.
You can then stretch out the screen to the size you want.
Let me know if this works for you.
Ed V.
Post by: josh on August 08, 2008, 11:30:41 PM
thank you guys, so very much
did exactly what you said and when I restarted mach
the screen fitted perfectly.
josh
Post by: ger21 on August 09, 2008, 05:54:10 AM
You can also close Mach3, right click in the middle of the desktop, and choose properties. Then click the settings tab, and change the resolution to 1024x768.
Post by: uuccimi on August 15, 2008, 09:18:48 PM
Try - Config
 - General Config
Config from mach3 because don't see the option General Config ecause from windows, to use other progrmas I have to go back to setting again and change resolution!!!
Post by: edvaness on August 15, 2008, 09:56:04 PM
Post by: uuccimi on August 15, 2008, 10:52:09 PM
I can see CONFIG - but where the GENERAL CONFiG are?
I have Mach3 ver. 1.84
Post by: edvaness on August 16, 2008, 02:08:15 AM
 UUCCIMI,
general config should be on the config tab. If not, go to view and reload your 1024 screen set.
It will be in your mach 3 folder.
Ed V
Post by: ger21 on August 16, 2008, 12:20:52 PM
There is no General Config in that version. Theres a Config>Logic and Config>State. I believe you want to look in Config>State.
