Mach Discussion => General Mach Discussion => Topic started by: DavidCousins on August 07, 2008, 02:18:48 PM
I'm a user that leaves the CPU of my Mach3 computer running overnight. Until last night when I had a power outage or some other reason to reboot. The computer restarted and Mach3 runs fine, however the machine's configuration didn't save.
The part that didn't save is Config>Motor Tuning>Steps per unit.
When I jogged my machine, I noticed the DRO moving at only half the distance. Which is a problem I had way back when I changed the micro stepping on the driver board. That was about a month ago. I changed the hardware drives to microstep, which means I had to change the Mach3 "steps per Inch" setting.
I can fix the steps problem, but How do a get Mach3 to remember my configuration? I don't have Mach3 available on this computer, but from memory, I'm sure I saved using the Configuration>Save function.
Is there something else I must do?
The other item that didn't save was the Button Editor. I changed some custom code but that code didn't save either.
Any help will be appreciated.
Sometimes the Save Config option doesnt work :( but shutting Mach down changing anything should save it.
