Mach Discussion => General Mach Discussion => Topic started by: inivator on July 31, 2008, 09:45:30 AM
I TRIED TO RUN THIS, BUT THE MACHINE DOES NOTHING. WHAT DO I NEED TO DO???????????????
INIVATOR
You have a Zero at 01234, it should be the letter o as in O1234
If Hoods suggestion does not fix the problem, then sub routines should be placed in the subroutines folder, and called by a G98 (call-my-sub-routine-name) in your GCode.
