Mach Discussion => Mach Screens => Screen designer tips and tutorials => Topic started by: Greolt on July 22, 2008, 03:32:26 AM
Is there any info anywhere on the format strings for sliders in Screen4?
Greg
Hey Greg, not sure if there is any info posted but if you tell me what your tryiong to do, I'll try and see if I can figure it out and post what I find.
I don't have a copy installed here at work, but if I recall, the L is the min value, H is the max value. I looked at the ones in the standard screen, they were something like STDL10H250 with the standard DRO string added on at the end. I found that if I removed the D (I think), It would not display the numbers with the slider. I didn't need them since I had a DRO displaying them. I wanted to make a horizontal slider, and Art said it was possible, but the info he gave didn't appear to be correct.
If there is any info out there, I couldn't find it.
Just checked, and I used this to get a slider that did NOT display the value.
SL10H200%0.3f
goes from 10 to 200. Even though it doesn't display the value, I accidentally found out that it didn't work correctly if I omitted the %0.3f
