Mach Discussion => General Mach Discussion => Topic started by: Overloaded on July 19, 2008, 08:10:23 PM
R3.041 Mill
The G-Code button has/had script in it, (the older version had OEM 8 which for some reason I cannot find in the OEM list.)
I was modifying the script in the Ref All button and when I was done, that same script ended up in the G-Code button as well. Weird
Anyway, could someone give me a screenshot of the script under the G-Code button in Version R3.041 ?
RC
HtmlDialog( GetMainFolder()+"Mach3MillGcode.htm" )
Just another wee tip, make up a custom profile and also copy the screenset you are altering to desktop, rename it and then paste it back into the Mach3 folder and load from the view menu. That way when you upgrade versions your profile and any changes you have made to the screen wont be overwritten with the standard ones.
Ahhhh....good tip !
All better now............thanks Hood
I am aware of the occasional "Save" not saving , but never had it jump to another button.
In the XLS you posted...was there an "OEM 8" for the old code list ? Or was I looking in the wrong place ?
rc
not sure
RC I see what you are meaning now, the older screens had the G-Code button set to OEM8 which meant it would open page 8, similar to the MDI button being OEM2 as that is the page number for MDI.
Now that the G-Code is a html page then it has to look for that instead of going to page 8 of the screenset.
Just a quick question, why do you guys upgrade to a version that is not a lockdown yet?
I'm just curious as I'm always a wuss when it comes to changing versions- :)
Quite a few reasons, main one I suppose is the later versions always have things that the earlier ones dont, whether they are an advatage depends on the individual. Another reason is for instance screen designer changed a while back, my screens wont run on early versions as lots of LEDs etc would be missing. Same with the SmoothStepper, it requires a later version than the lockdown version.
I like to try to keep up with the latest and greatest. I really like the Feed Rate and Rapid Overrides in the new version.
The proof is on the pudding too, if no one ran the new releases, they wouldn't get de-bugged through practical use and therefore would probably never get locked down.
I love to tinker with this stuff,
RC
I completely understand the reasons for upgrading, I just hate to bork up my system when things are running well.
I guess the best thing to do is set it up on a PC that I don't have my machine on and go through to be sure.
Thanks fellas-
That's what I do here. Machine is Locked down, simulatre the New R at the desk.
Cool Stuff,
RC
You can also keep a backup of your xml, any custom screens and macros and the tooltable. Usually you would just need to reinstall the earlier version over the top but if the worst came to the worst you would have all of your custom files backed up and you could be up and running in seconds. Never had to do that due to a Rev update, well should say SO FAR!!!! ;)
lol! I'm already there, my friend. I have a weekly backup system that includes all my files for that "just in case" moment! :D
It will [/size]happen, rest assured :D
