Mach Discussion => General Mach Discussion => Topic started by: carllance on July 19, 2008, 06:49:17 PM
Problem: Home/Limit switch is sensitive on Z axis. When I Reference it backs off the swith, but barely. When the machine begins a rapid move, sometimes the limit switch will trigger again.
Is there any way to instruct Mach to back off of the limit/home switch a bit farther after homing?
Thanks!
Carl
Try setting the debounce a bit higher, start at 2000 and work down until you get the problem again then back up a bit.
You can set a G28 position and alter the code in your RefAll button .
I have actually done the G28 change in the RefAll button for now. Good Idea!
As to debounce setting, doesn't that also effect limit switches in operation as well? What about all inputs?
Thanks!
Carl
Debounce will affect the limits etc, probably not as much as you would think but its definitely better to have it as low as possible.
A faster home move on the Z axis may also do what you need if it is indeed a very sensitive switch rather than a bouncy switch.
Carl
I noticed you posted about this on the SmoothStepper forum.
If you are using the SS it now has "digital filtering" or what Mach calls "debounce"
The good part about it in the SS is that it is a separate setting for homing, limits estop, probe etc.
So if yo set a substantial debounce interval for home switches it will not affect estop, limits etc.
Greg
