Mach Discussion => General Mach Discussion => Topic started by: Saumur on June 26, 2008, 11:05:21 AM
Hi guys,
when i load a g-code the screen with the toolpath shows up normally.
the problem is that if i zoom on it, after i edit the program the screen will unzoom and go back to normal position.
Is there a way to keep the toolpath zoomed as you prefere everytime?
thanks
No dont think there is, the reason being is when you edit the programme you are in effect reloading it and Mach regenerates the toolpath.
thanks for your answer, can some1 confirm it?
thanks
yes
