Mach Discussion => General Mach Discussion => Topic started by: marty on October 26, 2005, 04:35:56 PM
HI ALL
MPG
i will be geting one but i need some info
i will be useing mach3 i have added port
i thank incremntal 100 p/r not sure on the out put (totem pole) or (line driver) or (voltage)
and power supply (5~14vdc) or (5vdc) is thare one that is like
thank for the help marty
Hi Marty:
I use a 100CPR myself. I use a cuttoff USB cable for power. Works very well..
Art
Hi Art,
is there any key to hold the MPG-MODE constantly on the top of the screen?
Usually you get it via TAB – Key, but if you make any change between the pages the MPG-MODE disappears!
Regard
Horst
