G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Tiwanacote on May 09, 2008, 11:24:27 AM
Does anybody know any other cam program than Mastercam with a simple postprocessor creator to be used for Mach?
Regards
Tiwanacote
Use a Fanuc 6,11 or 18 post.
Graham.
Thank you Graham!
? is Fanuc 6 a program you can just get to use as a post processor?
I am in need of a "lazycam" type program that I can import a dxf wireframe
that has X, Y, and Z movements at all different but simple angles.
Is this something I can use.
Or should I just try to find someone who has a older version of mastercam that
can generate these moves?
Brian
Hi Brian,
DXF is not normally used for 3D, DXF is best for 2D drawings, IGES is for 3D. Fanuc 6 refers to a g-code format used in Fanuc 6 cnc controls that a CAM system produces code for.
