Mach Discussion => General Mach Discussion => Topic started by: vertigo on May 04, 2008, 12:07:09 AM
Hi guys, I want to use this DXF file and convert it to G code, but I'm not having any successful results with it. I have attached two files a DXF.file and paint.file. I using Proteus 7.2 to make my layout design and tring to use Mach2 to generate a g code so that I can use my HobbyCNC controller. I haven't had any problem with using Rhinoceros 4.0 with Mach2, just this DXF file doesn't work properly. I don't know what I should do next, I would be so grateful if someone here could try this DXF.file out and see if the G code generates the same image as the other file attached.
Edit: I have attached also the text files that Proteus has made, just incase that helps somehow.
