Mach Discussion => General Mach Discussion => Topic started by: moxy on May 03, 2008, 03:26:56 PM
Hi all, I'm using Eagle pcb to design (guess what!) pcbs and would dearly like to know how to convert my hard work into a gcode file. Any help will be much appreciated.
Many thanks
Les
Can you save the files as DXF, if so then maybe you can use LazyCAM to produce the code.
Eagle has cam functionality. How functional it really is I do not know.
Hi All, Thanks for the replies. I persevered with eagle and found that you can run a program called mill-outlines.ulp which does the job. It can then be saved as filename.plt. I still have to play about with it further to see what final results I get.
Many thanks
Les
Hi Guys, further surfing on the net has found a free download which does the job perfectly. Search for PCB-GCODE and you will get to the site. it creates code for both sides of the board and a drill file.
many thanks
Les
Thanks for posting Les, hopefully it will help others if they need such a programme.
There is an add-on four Eagle that will output a DXF file of your PCB design, it was developed by enthusiasts and is freely available or at least was freely available, I think I downloaded the add-on from Eagles web site quite some time ago seemed to work just fine, although I didn't have a mill to actually make a PCB.
Darren.
